I've just done a fresh install of the latest version of DNN, and all is working well apart from one thing.
When you click on "Browse Server" from the editor (Image or link), it does not show the list of folders - it only shows the Root Folder in the left-hand pane, but no files in the list. If you create a folder it does not show in the list, but it does create the folder which can be seen in the "Site Assets" section, and you can upload a file directly via upload -> send to server, but it does not show in the "Browse Server" section.
This is the popup link for the Browser-Modus: Image
Providers/HtmlEditorProviders/DNNConnect.CKE/Browser/Browser.aspx?Type=Image&tabid=21&PortalID=0&mid=355&ckid=txtContent&mode=Default&lang=en-US&CKEditor=dnn_ctr355_EditHTML_txtContent_txtContent&CKEditorFuncNum=1&langCode=en
Is this a bug in the latest version? Ive not had this before.
Thank you.
You may want to edit the permission settings on the root. Right-click the root folder and check it out
Sebastian, I am not quite with you … I do not have an option "Recursive sync" there. I have the following options: "Refresh", "Sync this folder" and "Sync this folder and subfolders". I have tried all these options. What can be the cause that I do not have the alternative "Recursive file sync"? /Peter
