DNN v9.12.00 Web API
 23 Subscribed to this forum
I have built for testing purposes a simple Web API, which works perfect locally but when I'm trying to reach the endpoint (by Postman or by Module) in the productive online version, I always get the error '401 - Unauthorized: Access is denied due to invalid credentials.'. The credentials are exactly the same in local and online version.
public class ExchangeOrderController : DnnApiController
    [HttpGet]
    [DnnAuthorize(StaticRoles = "ExchangeOrderDK")]
    public IHttpActionResult Get()
        try
            return Ok("Request was successful!");
        catch (Exception ex)
            return Content(HttpStatusCode.InternalServerError, ex.Message);
Does anyone know what the problem could be?
Martin
Do you see anything different in the headers between the two environments?
Are you sure the code is the same in both places?
Does there happen to be a WAF in production? If yes, are there any security policies/rules that might be getting in the way?
In the Response Headers Section I found the following difference:
Production (not working) > There is one entry which is only in the online Request available:
WWW-Authenticate: Basic realm="www.xxxxxxx.ch"
Does the domain match what you expect?
Yes, it does
Okay, interesting...
What about the firewall question?  Do you have anything like that getting in the way too, or no?
The next test I would perform after that, would be to backup the website, and restore it as a test site on the same server, as a Staging site.  This would also allow you to do further testing to see if it's the website itself or something else in your infrastructure.  For example, toggling debugging and whatnot.
Once you have the staging website up and running, turn on debugging in the website config file, in DNN itself (Host Settings), and in Log4NET to gather even more information.  When do all of them, you'll have all possible logging turned on.  Also, the URL provider may insert more/new/different details into the response headers.
If you want to save some steps in turning on all of the debugging, you can use our Upendo DNN Prompt command to do that.
...and look for differences in your IIS configurations
No WAF in use.
Enabled all debugging possibilities, I found  the following warning in Log-File:
2023-07-26 19:05:26,448 [ranger][Thread:109][WARN] DotNetNuke.Entities.Tabs.TabController - Invalid tabId -1 of portal 0
2023-07-26 19:05:26,448 [ranger][Thread:109][WARN] DotNetNuke.Web.Api.StandardTabAndModuleInfoProvider - The specified moniker () is not defined in the system
BTW: Code is the following
        [HttpGet]
            try
One thing that is very strange: My ISP told me that he can authorize successfully to my API with the FTP-Credentials (which have nothing to do with the users and roles inside DNN)
