Add functionality to create user
I need to add a functionality at create user procedure: when SuperUser/Admin creates a user throught the menù I need to insert the new user in a custom table, outside the DNN database.
What is the best practice: add code directly to AddUser stored procedure or other?
I would sugges these options:
A. Create / use  a custom Form for adding users.
B. A DNN Schelduted task
C. A Database trigger.
I would not change the DNN code as that will get lost when you upgrade DNN.
DNNSharp's Action Form can do this. I know there are others too.
Hi Timo,
I create a custom form
Posted By progmr on 09 Jul 2020 03:33 AM
Hi Timo,
Ok, good to hear you found a solution.
My start for a User manage template in Open Content van be found here: https://github.com/Timo-B...%234/User-Management
(for reference, still needs some work TBH)
