Admin logs taking lots of memory
Page 2 of 2 << < 12
Thanks again for your advice and information. I fixed the Host alert issue, but still need to figure out why the logs are so huge.
In the log file, there are many entries that look something like htis:
2021-06-16 00:15:08,078 [SCZAS51][Thread:22][DEBUG] DNN.Trace - PageBase.IterateControls Info (TabId:96,ControlId: )
Do you know what these are?
Tom
It appears that log4net is set up to log DEBUG messages.
The config file for log4net is DotNetNuke.log4net.config.
You will want to look at the "level" setting which, normally, is set for ERROR
The possible settings are:
ALL
DEBUG
INFO
WARN
ERROR
FATAL
OFF
So, if level is not set to INFO, I'd reset it to that.
And, you can delete the existing .log files.
Thanks again for this - I see that now. Our internet site is set to the ERROR setting.
Do you know the difference between the INFO and ERROR settings?
Thank you!
Google "Log4net."
INFO should contain more data ...
Thanks - One last question - after making this a change to the DotNetNuke.log4net.config , does the site need to be restarted? Does there need to be an IIS reset?
Thanks again for all your help
AFAIK, changing any .config file will restart the website automatically, but you may restart the app pool to be sure. No need for an IIS reset.
Thanks very much
Page 2 of 2 << < 12
