Await/Async not supported in DNN , what is the solution ?
I'm using DNN 7 , I'm trying to using await/async when calling payment api , but it's giving error not recognizing to async as below , please help me.
        protected async void Page_Load(object sender, EventArgs e)
            await getSessionAsync();
async System.Threading.Tasks.Task getSessionAsync()
            using (var client = new HttpClient())
                string sessionID,successIndecator = "";
                string amount = "100.00";
                string merchant = "700737";
                using (var request = new HttpRequestMessage(new HttpMethod("POST"), "API_URL"))
                    var contentList = new List();
                    contentList.Add("apiOperation=XXXXXXX");
                    contentList.Add("apiPassword=XXXXXXX");
                    contentList.Add("apiUsername=XXXXXXX");
                    contentList.Add("merchant=XXXXX");
                    contentList.Add("interaction.operation=XXXXXX");
                    contentList.Add("order.id=XXXXXX");
                    contentList.Add("order.amount=XXXXXX");
                    contentList.Add("order.currency=XXXXXX");
                    contentList.Add("order.description=XXXXXX");
                    contentList.Add("interaction.merchant.url=XXXXXX");
                    contentList.Add("interaction.merchant.name=XXXXXXX");
                    contentList.Add("interaction.returnUrl=http://localhost/tResult.aspx");
                    request.Content = new StringContent(string.Join("&", contentList));
                    request.Content.Headers.ContentType = MediaTypeHeaderValue.Parse("application/x-www-form-urlencoded");
                    var response = await client.SendAsync(request);
                    string result = response.Content.ReadAsStringAsync().Result;
                    if (result.Contains("session"))
                        string[] details = result.Split('&');
                        string[] sessionDetails = details[3].ToString().Split('=');
                        sessionID = sessionDetails[1].ToString();
                        string[] successIndecatorDeatils = details[6].ToString().Split('=');
                        successIndecator = successIndecatorDeatils[1].ToString();
                        sessionHidden.Text = sessionID;
                        Session["indicator"] = successIndecator;
                    else
                        sessionHidden.Text = "Failed";
Please tell us the error message. We cannot guess what is on your screen.
I'm guessing you're probably anticipating this, but you really shouldn't be developing against such an old version of DNN. It's highly recommended to upgrade to DNN 9.8 or newer, and all of the way to 9.11.00 if you can. The API's have changed several times since then, and there are also several hundred other updates that will be missing - many of which might be performance-, feature-, and security-related.
