block a BOT on a multi portal site
Hi, has anyone got any idea how to block a bot to a parent portal in a multi portal site. Am I right to understand we cannot use  Robots.txt  and that sitemap.xml in a portal can be used ?? but has anyone an example?
You could maybe disallow the root and allow some subfolders using robot.txt?
Hi Timo, I found a blog post about using request filtering in the web config file.
Has anyone any experience with this type of approach and will it work, more importantly, are there any side effects.
Robots.txt works fine with a DNN site.
OTOH It depends what you mean by block. Robots.txt is just a convention. It ASKS bots to stay out. They don't have to pay attention.
