disable /VerificationSuccess/true
I use a DNN verified user registration and a custom registration module /myCustomPageWithLogin
and this page is a dynamic page like myCustomPageWithLogin?ID=3132 which at return become myCustomPageWithLogin/ID/3132 but still working
In order to verify the users email I have a regular DNN Login module with permission for Unverified Users.
The registration module is sending this link to verify and in the same time I want to return to the dynamic URL
https://domain.com/myCust...ageWithLogin/ID/3132
but seems that the DNN Login it returns allways to the root page where the login module is myCustomPageWithLogin/VerificationSuccess/true
How I can disable this verification success link and redirect to my custom link? There is a way to verify the users other than using verification code?
thank you!
Can you please explain the situation differently? I'm not really understanding your question.
Which version of DNN are you using?
You mention a custom registration module. Please provide some more details there.
Hi Joe,
I do use XMOD Pro & FormX with a custom Registration module and I can create a custom email with validation code in it. And this link has to point a page where the DNN Login module in Uverified Users permission mode in on that page so the User gets approved.
Just that the Login Module is rewiriting the link I created allways with   domain.com/mypage/VerificationSuccess/true
My need is actually to return to a dynamic page I have in the domain.com/mypage?ID=999
So I startedo to create a workaround but I got another issue: Even I have updated the UsersPortal Autorised=1 and Change the roles form UnverifiedUser to RegisteredUser and the users Show: Authorized, the flag in Account Data is still False. Then, after a while, magically it updated. And this explains me why in the past some user created the accounts and complained that the verified email did not worked.... Any explanation for this behavior?
https://ibb.co/vxGLTF4
The issue was cache. I overcome the issue adding to Registerd Users after the main stored procedure.
Still if the DNN Login will be changed to permit to disable the confirmation message then I could use it. For now I had to create a custom email validation.
