DNN Feedback Module
I am not a coder at all, although I have been trying to learn a little bit here and there.
I was just wondering if the DNN Feedback module is able to be modified, as it would be great for my needs if it was displayed slightly differently.
At the moment if has the 2 sections, Your Contact Information and Your Feedback.
Is it posible to alter it, so the 2nd section heading text (Your Feedback) is removed but the field are still able to be used?
I've looked through all of the settings but I cant see anything obvious.
Kind regards,
Matt
AFAIK, the module is not templatable.
Your best bet is to hide parts using CSS I think.
Sorry, the views do get rendered from a template
Thank you for your reply.
Unfortunately I know next to nothing about CSS.
The complete source code for the module is available, so you could employ someone to completely customize it for you.
A (better) approach would be to use on of the many quality forms modules to create something that matches your requirements. I'd recommend Live Forms (Mandeeps), Action Form (DNN Sharp) in the commercial realm but not terribly expensive. Open Form (https://github.com/sachatrauwaen/openform) is a free, open source module.
Posted By mattfarmer on 06 Nov 2019 09:59 AM
I use the module on this website: https://thankshaun.org/
Add message: https://thankshaun.org/add-a-message
What exactly are you trying to accomplish?
Hi Timo,
Your link: https://thankshaun.org/add-a-message
That is pretty much exactly what I am trying to achieve!
I may want to add a field for a users phone number and change the button text to Send, but apart from that, it is spot on.
How did you manage to alter the module to achieve that configuration?
Do I have to try and learn CSS, I am more than willing to give it a go but I just don't know where to start with things like this.
If i'm honest, that is the reason I started using DNN many years ago, because I could just buy modules (from snowcovered) and they were fairly easy to configure with the basic settings.
Any help, is much appreciated.
Kind regards,
Matt
Hi Matt,
I added this css:
<code>.NarrowFeedbackForm h2 {<br />     display: none;<br /> }</code>
Here are my settings:
Settings
I'm really sorry is this is a silly question but where do I paste the css code?
I did the following but it didn't remove the 'Feedback' section, (even after a ctrl+f5)
Settings - Develop, then selected the module.css file and pasted your code at the bottom, then clicked on Update.
Should this have removed the 'Your Feedback' section, or am I mistaken?
Thank you,
Matt
You should not add this to the module.css as it will be overwritten on upgrade.
You can either add this to your theme or use (DNN9) Settings > Custom CSS
This will edit Portal.css which resides in the Portal folder (example: "/Portals/0/Portal.css")
