Customizing SiteAnalytics.config
Hello
I would like to customize SiteAnalytics.config in order to use Opt-out.
I read https://developers.google...yticsjs/user-opt-out article. Since the window['ga-disable-UA-XXXXX-Y'] = true; call should be set before any ga() call, I think that I should modify that .config file. Any suggestion for implementation of opt-out?
Thanks!
Siteanalytics.config is just HTML that get's injected, you can add any script you want in there, so you can also add a script that generates a toolbar and reads an opt-out cookie. But you should be aware that that's for all portals.
If this is only for one Theme, I prefer not to enter the google id in DNN but just add everything to the Theme.
