DNNPlatform HTML Module Question
I currently have a website that is created using DNNEvoq. We are finding we aren't using any of the features of Evoq to justify the cost. So I spun up a test server and installed DNNPlatform to make sure our site will work and see if we will lose any of the features we do use.
I then exported some data from the live Evoq site and imported it into the DNNPlatform instance and it appeared to work fine. However I am having issues with the HTML module.
When I click on the Edit content button a modal window opens up but doesn't show any content or even an editor. I am used to doing this in Evoq and seeing the advanced editor window. All that shows in the window though is a link that says "Custom Editor Options", below that are a horizontal and vertical scroll bar that is not usable and then below that is the buttons for Save, Cancel, etc. I can edit in the quick edit portion on the web page but it doesn't have all the same options that I was used to in the Advanced editor like "View Source".
Any idea what is missing or what needs to be done to fix this?
I'm afraid there is more to it to migrate from Evoq to platform. In the paste I tried the export - import as well but you rather migrate from Evoq to platform using a bunch of scripts. Now, I do not have a blog/script but maybe someone else does. Let's see if I can shake some trees.
Here is a YouTube playlist that consists of a number of videos of the "proper" (although unsupported way) to move from Evoq to DNN Platform:
https://www.youtube.com/p...76lcDD6edV-dUEnbG2Ew
Nice, Justin! Didn't know this one.
I just added the series to https://dnncommunity.org/Resources/Videos for future reference
