Export Site From DNN 9.32
I had try to export site: Page, content... from DNN 9.3.2.
But after that i find file template.\Portals\_default\.template are empty. I want exportsite and create new site from same data.
Like DNN 7.xx
You might have missed this on the Import/Export screen:
"Your site export files are securely stored within your website's App_Data/ExportImport folder."
Posted By Joe Craig on 27 Nov 2019 09:55 AM
Dear Joe,
Tks for help! I had find solution to do that. DNN 9.x are many change with DNN 7.x.
I must export Site. After that run schuelder. :(
Hi Joe,
I am experiencing the similar issue.
I was able  to export the site by using Import/Export option from settings.
But  I can't see  site export files under  website's App_Data/ExportImport folder.
any inputs please?
Posted By Aparna on 4/3/2023 3:09 PM
Hi Joe,
any inputs please?
In what version of DNN did you export?
What Joe describes in for DNN9+
Perhaps, access it the problem.  If there are no errors, then the process probably happened exactly as it was supposed to.  However, you must access the file system directly to see the results of the export process.  This means logging into the server and navigating to the hosting folder and/or using FTP to do the same.  Have you tried either of those options yet as well?
