General Exception Errors 9.4.4
I have two recurring general exceptions showing up in the logs. I spent the past two days trying to track these down with little success.
Error #1:
AbsoluteURL:/LinkClick.aspx
AssemblyVersion:
StackTrace:
InnerStackTrace:
   at DotNetNuke.Entities.Portals.PortalSettings..ctor(Int32 tabId, PortalAliasInfo portalAliasInfo)
   at DotNetNuke.Entities.Urls.AdvancedUrlRewriter.Handle404OrException(FriendlyUrlSettings settings, HttpContext context, Exception ex, UrlAction result, Boolean transfer, Boolean showDebug)
   at DotNetNuke.Entities.Urls.AdvancedUrlRewriter.ProcessRequest(HttpContext context, Uri requestUri, Boolean useFriendlyUrls, UrlAction result, FriendlyUrlSettings settings, Boolean allowSettingsChange, Guid parentTraceId)
   at DotNetNuke.Entities.Urls.AdvancedUrlRewriter.RewriteUrl(Object sender, EventArgs e)
   at System.Web.HttpApplication.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
Source:
FileName:
FileLineNumber:0
FileColumnNumber:0
**I cannot reproduce this myselt using the url on my domain url.  And there is no log entry before or after that shows a 404 error for LinkClick.aspx
Error #2
AbsoluteURL:/DnnImageHandler.ashx
InnerMessage:The process cannot access the file
[I Removed The Path]\_imagecache\[I Removed The Name].tmp' because it is being used by another process.
InnerStackTrace:
   at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
   at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
   at System.Web.HttpResponse.TransmitFile(String filename, Int64 offset, Int64 length)
   at System.Web.HttpResponseWrapper.TransmitFile(String filename)
   at DotNetNuke.Services.GeneratedImage.DiskImageStore.TryTransmitIfContains(String id, HttpResponseBase response)
   at DotNetNuke.Services.GeneratedImage.DiskImageStore.DotNetNuke.Services.GeneratedImage.IImageStore.TryTransmitIfContains(String id, HttpResponseBase response)
   at DotNetNuke.Services.GeneratedImage.ImageHandlerInternal.HandleImageRequest(HttpContextBase context, Func`2 imageGenCallback, String uniqueIdStringSeed)
   at DotNetNuke.Services.GeneratedImage.ImageHandler.ProcessRequest(HttpContextBase context)
   at DotNetNuke.Services.GeneratedImage.ImageHandler.ProcessRequest(HttpContext context)
   at System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
***For this error, I saw a post that recommened adding the setting to turned off Server Cache for the ImageHandler.
What version are you running? And how is the url rewriting set?
