hacked with unknown image
an image shows up at the the bottom right of the screen no link to anywhere. Initially it was redirecting to some page here chianxiaoshuo.net
I can't find any trace on the website.
I can see it when I go to https://momzey.com but it does appear on the same website with a different subdomain https://2019.momzey.com
any help to figure out where it may be coming from would be greatly appreaciated
It is acting as if it is coming from DNS  but there are no records in the DNS to suggest it.
check ModuleSettings and PortalSettings tables for references to the code that is being added
e.g.
SELECT * FROM [ModuleSettings] where [SettingValue] like '%todelete%'
Hi Franc,
Most likely the vulnerability that has been used is Telerik related.
The script most used widely will upload an aspx file in the root. This file then allows to place content. In the version history you will see that the content has no author.
So, you need to remove the malicious aspx files and upgrade.
The aspx files that are legit are the default.aspx, Errorpage.aspx and keepalive.aspx. All others are suspect and need investigation. I have seen instances where dotnetnuke.aspx was placed which looks legit but was not.
Thanks  for the help, I only have the 3  legit files you mentioned. Also this issue first appeard on 4/14/2022 I don't see any files of anytype that have been added or edited recently
not sure if the hack would have updated the modified date on the folder
I did run the query for module setting and portal setting did not return any info for '%todelete%'
I am also not sure what I am looking for. I can be just a lose nut in front of the CRT
No, the folder date won't tell you much.
If you have rdp, you could try a search for .aspx in general.
Sometimes they create a folder /video and place a file there.
I did search for *.aspx in the root folder and found 58 items with ASPX file type on different folders. Most look like they are associated with different modules. Don't know what to look for inside these files.
last modified 8/1/2021 HabuMiyar.aspx
If you want, I could take a look at things for you. Either via FTP or if you feel uncomfortable with that, we could screen share so you can watch my every move :-)
You can reach out to me at [email protected]
i'll send you remote desktop credentials
