Issue with Mobile Infinite Redirect Loops
Hi there,
I'm having an issue with a newish DNN 9.6.2 Community Edition site that I'm trying to set up. This is made with a responsive design, so it is meant to be only one website for both desktop and mobile users. I can access the site fine on desktop.  However, when I try accessing it on mobile, I get into a whole bunch of redirects which then eventually errors in Chrome and Safari. In the HTTP response, the HTTP header value for x-redirect-reason is Wrong Portal Alias Requested.
I noticed in the headers that it seems that the DNN module for detecting the device type and redirecting as necessary is enabled, as the dnn_isMobile cookie value is set to 1 in it (I can reproduce on my desktop by going into a mobile view via the F12 Chrome developer tools). In my Site Aliases configuration section (and confirmed in the PortalAliases table), my portal aliases are all set up to use Canonical for Site Alias Mapping Mode. I have set up all of the various aliases as needed, and the BrowserType is set to Normal.
Since the issue seems to be that there's the mobile detection and redirection happening errenously and redirecting into an endless loop, is it possible to disable this mobile redirection feature? I have searched far and wide for determining how to do this in the documentation and online, but can't seem to find the correct setting to do so. I may have overlooked it though.
Like I said, this is a modern site we're building and not doing anything like a separate mobile portal or anything like that, so it's better to just not use this mobile redirection feature at all.
Please let me know if you need more details. I would really appreciate any assistance on this!
Well, it turned out to be something really silly. When I verified this against a separate fresh DNN install, mobile worked out of the box. The only difference I noticed was a primary Site Alias was set, but no primary site alias on the other site I was having issues with.
Once I set a primary site alias, the redirect errors stopped happening and worked correctly. I'm not sure if this is a bug or not in the end of DNN, but that's the way to resolve this particular issue at least.
Edit: The only caveat is that when trying to access any other non-primary url with Site Alias set to Browser Type 'Normal' on mobile is that the same redirect loop. If you set the type to Mobile, it will work on mobile, but then the redirect loop happens on the desktop browser.
So, my issue is resolved and this can be worked around for me, but I guess the question really is if there's a way of telling DNN not to care about the Browser Type for any site alias and no do any mobile detection and redirection regardless if the the site alias being accessed is primary or not.
