DNN Search not working
I have a system I am working on whereby I am using the DNN Search module for the site. It is running DNN 9.4.1
Everything seems to be working fine except the following:
  • "See More Results" not working
  • Some items from modules are not appearing in the search
When I click on the see more results as seen in picture below, nothing happens. There are also no js errors shown in the console.
Secondly, some of the items that i want the search to show is not showing up in the search module. I have already checked all the boxes of the components to include in search function.
Is there something that I can do to rectify these issues that I am facing? Thank you.
Andy,
you could try to stop the application pool, delete all files from the App_Data/Search folder, and restart the app pool. The go to Settings :: Site Settings, select the Search tab and click on "Re-index Content". It might last a while, but the index should be created from new by this.
Anyway, I would also recommend to upgrade the site to a more recent version (9.7.2 is current, but there is a bug in it that might break your site if you use some VB extensions (known: 40fingers Style Helper, so please test before).
