Malware in FileAnalytics.aspx
Hi all, have a DNN8 version that gave me this message when running AVG Antivirus check: ASP:Shell-AQ[Trj] in C:\DNN8\Install\AuthSystem\apt\FileAnalytics.aspx
Can i delete the file and make an upgrade? And what version should that be?
That file is not a part of DNN Platform, and that path isn't where any resource would typically be installed. I would definitely recommend deleting that file.
The recommended upgrade path suggests upgrading to 8.0.4, then 9.1.1, then 9.3.2, then to the latest (currently 9.8.1).
Great. Thanks, i'll try that and will make en upgrade.
