Manual Deletion of a Child Portal
I am running a website on DNN 9.1.1 with three child portals. I want to delete number 3. When I went to the sites menu it says "error" when attempting to delete it. Moreover, I notice a trouble ticket was put in for this a long time ago and it seems not to have been solved. I am limited on time. Would someone be willing to tell me how to manually delete this portal because this domain needs to be moved to its own instance of dnn on a seperate hosting. Thank you in advance for your help.
It should be able to delete the portal, but probably not if you are doing this from the portal in question.
Go to another portal in the same installation as super user and visit Site Management. Can you delete it from there?
Something in the back of my mind remembers a problem with deleting portals early in the 9.x line, you you might be seeing this.
I'd do this. Make a copy of the existing installation and install it. Set the IIS bindings and portal aliases in the new installation to point to the portal in question. You'll want to remove those same bindings and aliases to the orginal installation. Don't create bindings in the new installation to the portals you don't want to move.
Then, the original installations version of the portal can't be reached, but the new one can.
Then, you should update both installations to 9.5.0. (or do that before you move a copy to the new installation.)
Thanks. Apparently they did get it solved and didn't close out the ticket. Upgrading to 9.5.0 solved the issue. I was able to delete the site.
