Critical Error
So out of nowhere my site is suddenly giving the error "A critical error has occurred. Please check the Event Viewer for further details."
I cannot access the persona bar at all.  It worked fine two days ago, the last time that I logged in, and suddenly it no longer works.
DNN 9.4.3
I cannot find the full error text in the database.  Not sure where to look, but in the EventLog table, the LogTypeKey is PAGE_LOAD_EXCEPTION.
I am not sure where to go from here.  I can't login at all with any admin or above account.  All I get is this error.
Ok, I was able to find the EventLog View table. Here is the full error.
You must specify a non-autogenerated machine key to store passwords in the encrypted format. Either specify a different passwordFormat, or change the machineKey configuration to use a non-autogenerated decryption key.
at System.Web.Security.MembershipProvider.EncryptPassword(Byte[] password, MembershipPasswordCompatibilityMode legacyPasswordCompatibilityMode)
at System.Web.Security.SqlMembershipProvider.EncodePassword(String pass, Int32 passwordFormat, String salt)
at System.Web.Security.SqlMembershipProvider.CheckPassword(String username, String password, Boolean updateLastLoginActivityDate, Boolean failIfNotApproved, String& salt, Int32& passwordFormat)
at System.Web.Security.SqlMembershipProvider.ValidateUser(String username, String password)
at WebMatrix.WebData.SimpleMembershipProvider.ValidateUser(String username, String password)
at DotNetNuke.Security.Membership.AspNetMembershipProvider.ValidateLogin(String username, String authType, UserInfo user, UserLoginStatus loginStatus, String password, Boolean& bValid, Int32 portalId)
at DotNetNuke.Security.Membership.AspNetMembershipProvider.UserLogin(Int32 portalId, String username, String password, String authType, String verificationCode, UserLoginStatus& loginStatus)
at DotNetNuke.Entities.Users.UserController.ValidateUser(Int32 portalId, String username, String password, String authType, String verificationCode, String portalName, String ip, UserLoginStatus& loginStatus)
at DotNetNuke.Modules.Admin.Authentication.DNN.Login.OnLoginClick(Object sender, EventArgs e)
at System.Web.UI.WebControls.LinkButton.OnClick(EventArgs e)
at System.Web.UI.WebControls.LinkButton.RaisePostBackEvent(String eventArgument)
at System.Web.UI.WebControls.LinkButton.System.Web.UI.IPostBackEventHandler.RaisePostBackEvent(String eventArgument)
at System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument)
at System.Web.UI.Page.RaisePostBackEvent(NameValueCollection postData)
I have no idea what this means, or why it would out of nowhere matter...
Hey Aaron, did you find any resolve for this issue?
