Messaging Scheduler Message Dispatch issue
The messaging scheduler is not working regularly; it sometimes succeeded and other times failed with no reason!
I found some records at the [<code>CoreMessaging_MessageRecipients&#93;</code> table that weren't get sent by the scheduler
Here is the query that I used to get them
select * from CoreMessaging_MessageRecipients where EmailSent = 0
I found some error logs from the admin logs viewer https://prnt.sc/24nz5nj
Anyone can help?
Hmm...'with no reason' is rarely correct :-)
It is hard to determin what could be the cause of the 'object of a reference not set'.
- Just outside of the screendump there is an exception regarding the scheduler. Maybe it is related? It is the same timing.
- What DNN are you running?
