Missing host settings UI
EPT
The DNN PersonaBar does not have a UI for all available host settings, thus you are not able to modify those settings via the UI.
Do you have a complete list of those settings and are you willing to sahre that list here?
EPT, I am not sure, this is feasable as any module (including EVOQ suites) may add items to host and portals. My Turbo Scripts include script AdjustDNNHostSettings932.sql to ensure the most relevant items contain valid values.
EPT
Hi Sebastiaan. Tnx for the reply.
I am just looking for a list of settings I should add or edit manually (using SQL), items that are not available in the PB.
Maybe take a look at the Host Settings chapter in the DNN 7 book?  :D
Do we have a list of what's still not available in the Persona Bar that used to be in the Control Panel? I think Enable/Disable Popups is one of them, right?
one important missing feature is the Lists editor. I just created a script to fix the system lists, but custom lists could be used for user profile properties or modules - which does not make sense anymore without the editor
