New Resourcemanager
 12 Subscribed to this topic
Page 3 of 3 << < 123
Something must have gone wrong with your update. For me it looks like this in DNN 9.11.1:
Sorry, it's the German localization, but this it is for me.
I have the same result as Michael, but in English.  :)
Same here... in both 9.11.1 as 9.11.2 the Copy URL is not present.
We're running v9.11.2 and we don't have the "Copy URL" function either. But my problem is the underscore issue when you download a file where the filename contains spaces. We have 100's of files posted and many upset employees. I would like to know if there are plans to remedy this or are we expected to rename all the files that contain spaces. It didn't seem to be much of an issue on GitHub which I found surprising.
as a workaround for the underscore/space issue, would a rewrite rule in IIS be ok until a proper fix is in place?
Seems to be related to the use of SSL. Check out this link: https://dnncommunity.org/...s/aft/3607/afc/10118
Has it been solved somehow why the Resource Manager is not showing "Copy URL" function ? I'm using version 9.12.0
Hi Michal, that functionality it's not available yet, why don't you log this as a new feature request in the issue section in GitHub? This is the https://github.com/dnnsof...pen+resource+manager">link https://github.com/dnnsof...ce+manager (Make sure you follow the template provided :-D )
Hi Marco,
the situation is quite confusing, I read in this thread that someone has already seen the function (including screenshots). So I thought there is some problem with my site (something set incorrectly). The information that the feature is actually not there is kind of surprising.
Posted By Michal on 9/6/2023 3:13 PM
Hi Marco,
The "problem" is that this thread started when we where still using an inherited file manager from Evoq.
But as that one had UI/UX issues, a new version was created from scratch, which intitially did not contain contain the copy link function but now it should. See this issue: https://github.com/dnnsof...Platform/issues/5725
