Page Permission Caching issue
We are experiencing an unusual problem in our production environment where changes(page permissions) made on one server are not being reflected on another server for a period of 15-20 hours. It is possible that the changes are only taking effect after the application pool is restarted or some other action is taken.
I am wondering if there might be a configuration setting which can solve this, restart application solves it but we can not do it after every changes.
Is this Evoq or Platform, what caching provider is used in Servers -> Performance ?
This is Platform, and i have tried multiple combination from Server->Performance from but no luck, please fine below recent one
Ok cool, that looks like what I would use, however I don't do multi-server so hoping someone else can help :)
By no means an expert, but here are some things to consider:
1. Is IIS configuration same on each server ? Like making sure worker process in application pool set to 1
2. Is only issue with page permissions ? Are other “farm” features working correctly?
3. Have you tried changing cache provider to “web request cache provider”?
4. File change notifier. Is it set up on each server?
5. Cache synchronization handler. Is it configured in web(dot)config? Do you see calls to it in iis logs? With success/error 200?
AIUI multiple servers - aka a web farm - is not a supported configuration for platform.
So there are no promises for cross server synchronization.
I have seen it work but it is a complex setup, you need file replication of some sort, a load balancer and a caching provider than can invalidate cache everywhere. The purpose of the SimpleWebFarmCachingProvider is exactly to make those scenarios work on Platform. Corp used to have some documentation if you try to google (Dnn wefarm setup), I don't know hom maintained that documentation is, but I remember it used to explain how to setup for caching, scheduling, etc.
Thanks @johnhenley
JAS> yes its same for all servers.
JAS> Mostly related to page management e.g. add/udpate, permissions etc.
JAS>Yes, i have tried that too.
JAS>We have one shared file server for all web server.
JAS>Yes, that's configured. i dont see any info in admin logs, need to check IIS logs.
Thanks Daniel Valadas
SimpleWebFarmCachingProvider might do the trick, for now i have same URL for all the servers, may be that's where i am missing. Let me try to add different URL for each server so they can call separately.
I would just add on that if you aren't already upgraded o the most current version of DNN, you should upgrade DNN first. 😉
