Path not found errors
Recently I have changed my site configuration, and now files folder is a file share in azure.
For some reason i started to receive error
2021-10-20 16:04:54.989+00:00 [vm-portal-prod2][D:17][T:66][FATAL] DotNetNuke.Web.Common.Internal.DotNetNukeHttpApplication - System.Web.HttpException (0x80004005): Path not found
   at ClientDependency.Core.CompositeFiles.CompositeDependencyHandler.ProcessRequestInternal(HttpContextBase context, String fileset, ClientDependencyType type, Int32 version, Byte[] outputBytes, OutputCachedPage page)
   at ClientDependency.Core.CompositeFiles.CompositeDependencyHandler.System.Web.IHttpHandler.ProcessRequest(HttpContext context)
   at System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
This is being writed on log files.
Site is working perfectly, js and css files are being compose without problems, but those errors are appearing on log files.
Version Im using is 9.3.1
Thanks.
Are you using DNN Platform or Evoq?
Did you install an Azure folder provider?
DNN 9.3.1 is not the latest version. For security reasons, I suggest upgrading to DNN latest version (9.10.2 since today, see https://github.com/dnnsof...n.Platform/releases)
Im using Community Edition, with azure file share. I have installed the azure extension but is not configured, im using file share as UNC folder for my server.
Paul,
it is propably because the application pool identity does not have the necessary permissions on the UNC share. It's better to configure the Azure extension.
Thanks Michael and Sebastian for your responses, I will try to update installation yo the last version an then install azure extension to see if that resolves the issue
