Re-create composite files
I ran into a little problem with the messages function (look for details at this GitHub issue). When I use the workaround documented in the issue (changing a bit of a Javascript) it works fine - but only when composite files (Server >> Server Settings >> Performance) are turned off. When turning it on again, it does not work.
Is there any way to re-create the composite files, or how can this be solved?
I think the quick and dirty way would be not to use the CRM to load your script..
Posted By Timo Breumelhof on 12 Jun 2020 06:31 AM
The script comes with DNN... :-(
(It has to do with this issue (and I have already submitted a pull request...)
Happy DNNing
OK..
