Redirect after login
After upgrading from 9.6.2. to 9.10.2 we have an issue with the redirect after login not working anymore...
The Redirect after login doesn't work when you have a custom login page (inloggen) set in "Site Settings" - 'Site Behavior" - "Login Page" is set to page from dropdown (Inloggen).
When the "Login page"is not set the redirect after login does work.
Is there a fix or workaround for this problem.
Two things I recommend you (1) get your website up to the latest current version of DNN and (2) if the problem persists you should log the issue at Git hub, here's the link: https://github.com/dnnsof.../Dnn.Platform/issues
I upgrade to DNN 9.10.2 and to RC 9.11.0
here is the github issue: https://github.com/dnnsof...Platform/issues/5044
Willem,
RC 9.11.0 is a Release Candidate - you shoul only upgrade to this version in a testing environment and not a production site. And even if the upgrade goes well, it is only for testing.
Michal
