registration settings
I would like to change registration setting from Public to Verified, when I do I get "cannot update registration settings Please try later"
does anyone know what could be preventing the setting from Public to Verified?
Any help will be greatly appreciated.
I am using a DNN instance 9.1.1 and cannot upgrade until I replace a module.
Check that you don't have different users with the same email address.
If you do, it may be helpful to change one of them to have a + sign, e.g. [email protected] -> [email protected]
I deleted all duplicate emails and still cannot make changes.
I tried to set registration to None and it didn't save the changes either
any hints in event log ?
nothing on the logs, is not generating any errors,
some consistency checks...
check there is only one portal...
        select count (distinct portalid) from [UserPortals]
...and check that these underlying tables have the same number of rows...
        select count (*) from [Users]
        select count(*) from [aspnet_Users]
        select count (*) from [aspnet_Membership]
James, thanks for helping. I just realized a developer that worked on this added authentication providers Google and Facebook not from DNN and probably did some other things that I need to get rid of before I can make any changes.
There is another portal on this DNN instance and on that portal I can change the registration to Verified.
There are 2 portals and the rows of users in the tables are all the same  One user on the second portal
OK - best to clear/clean other things first. I hope that you get it resolved.
