Setting up SSO with Azure AD
I downloaded the DNN Azure Active Directory Provider from Github and have been trying to set it up using the included instructions.
However after following the instructions when I click on the login link on the website I get a 404 Error.
Anyone have any suggestions?
What is the URL trying to load when it returns a 404?
Appears to be going to the login page;
"https://www.publichealthgreybruce.on.ca/GBPH-Login-Page?returnurl=%2f"
The URL it is going to is the same whether the Azure AD module is enabled or not.
Since that is a third-party extension, and there is a way to contact the vendor/developer behind it there - you may want to ask the question in their Issues and/or Discussions area. :)
Posted By amurraygbhu on 6/15/2023 1:27 PM
This looks like a browser cache issue...
Anyway, the DNN AD Authentication provider has not been maintained for a while, it still works but has some restrictions. One of them is it does not support LDAPS, and I can imagine that this is the problem with Azure AD.
Have a look at Active Directory | Glanton Modules - this might sove your problems.
When I look at the Azure AD module from Glanton it appears the module is no longer available in the DNN Store.
Most really good modules are sold only by the vendor. It looks to me as that DNN Store is slowly dying, it is owned by DNNCorp that has nothing to do with us, the community.
@amurraygbhu
Although, not in the store, Upendo ventures (Will Strohl and his team) have taken over the services around the Glanton modules.
Posted By Tycho de Waard - Tjeps on 6/19/2023 6:04 AM
@amurraygbhu
We'll be making more announcements around these modules ASAP.  We have a few more T's to cross and I's to dot. :)
Will
Is there any update on progress? would like to be able to my hands on the Azure AD module to see if it meets my requirements.
