Telerik Removal
Hello
I am on DNN 9.8.0 and I am in the process of removing Telerik from the site by following the instructions on Github DNN Platform for 9.8.0
I have reached number 8 on the list
8. Navigate to Settings > Extensions (Modules) in the Persona Bar and uninstall the Digital Assets Management extension. Be sure to check the Delete Files checkbox.
However, I am unable to Uninstall the Digital Management Extension, because there is no delete bin next to the extension as expected.
Further, there is no delete bin to Uninstall the next three extensions mentioned in numbers 9, 10 and 11 which also need to be deleted.
9, DotNetNuke Telerik Web Components extension
10 DNN Deprecated Web Controls Library extension
11.DotNetNuke Deprecated Website Codebehind files extension.
I am at a loss and unable to complete the instructions.  Please advise.
Thank you.
This is most propably because the Digital Assets Management extension is marked as a system extension. Did the SQL script in step 6 run without any errors?
Thanks for your reply Michael. I did run the SQL script, in step 6 and to be honest, nothing appeared to have happened, because no message appeared to say it was successful, but no errors showed up either, so it must have worked.
