ToggleUserMode 500
I have searched and tested everything I found on google concerning this error, maybe someone can translate these error codes
Your help will be very much valued
Chrome Console
https://mydomain.XX/API/i...olBar/ToggleUserMode 500 (Internal Server Error)
send @ jquery.js?cdv=1446:11
ajax @ jquery.js?cdv=1446:11
rawCall @ sf.js?cdv=1446:89
call @ sf.js?cdv=1446:100
post @ sf.js?cdv=1446:104
toogleUserMode @ main.js?cdv=1446:1086
(anonymous) @ main.js?cdv=1446:1089
handleClosePersonarBar @ main.js?cdv=1446:146
handleEdit @ main.js?cdv=1446:1088
dispatch @ jquery.js?cdv=1446:6
q.handle @ jquery.js?cdv=1446:6
ERROR LOG
2020-11-20
 00:04:33,200 [RD00155D586853][Thread:11][ERROR] DotNetNuke.Common.Internal.EventHandlersContainer`1[[DotNetNuke.Entities.Tabs.Actions.ITabSyncEventHandler, DotNetNuke, Version=9.8.0.0, Culture=neutral, PublicKeyToken=null]] - The type initializer for 'DotNetNuke.ExtensionPoints.ExtensionPointManager' threw an exception.
System.TypeInitializationException: The type initializer for 'DotNetNuke.ExtensionPoints.ExtensionPointManager' threw an exception. ---> System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.CodeAnalysis, Version=2.9.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. The system cannot find the file specified.
   at System.ModuleHandle.ResolveType(RuntimeModule module, Int32 typeToken, IntPtr* typeInstArgs, Int32 typeInstCount, IntPtr* methodInstArgs, Int32 methodInstCount, ObjectHandleOnStack type)
   at System.ModuleHandle.ResolveTypeHandleInternal(RuntimeModule module, Int32 typeToken, RuntimeTypeHandle[] typeInstantiationContext, RuntimeTypeHandle[] methodInstantiationContext)
   at System.Reflection.RuntimeModule.ResolveType(Int32 metadataToken, Type[] genericTypeArguments, Type[] genericMethodArguments)
   at System.Reflection.CustomAttribute.FilterCustomAttributeRecord(CustomAttributeRecord caRecord, MetadataImport scope, Assembly& lastAptcaOkAssembly, RuntimeModule decoratedModule, MetadataToken decoratedToken, RuntimeType attributeFilterType, Boolean mustBeInheritable, Object[] attributes, IList derivedAttributes, RuntimeType& attributeType, IRuntimeMethodInfo& ctor, Boolean& ctorHasParameters, Boolean& isVarArg)
   at System.Reflection.CustomAttribute.GetCustomAttributes(RuntimeModule decoratedModule, Int32 decoratedMetadataToken, Int32 pcaCount, RuntimeType attributeFilterType, Boolean mustBeInheritable, IList derivedAttributes, Boolean isDecoratedTargetSecurityTransparent)
   at System.Reflection.CustomAttribute.GetCustomAttributes(RuntimeAssembly assembly, RuntimeType caType)
   at System.Reflection.RuntimeAssembly.GetCustomAttributes(Type attributeType, Boolean inherit)
   at Microsoft.Internal.AttributeServices.GetAttributes[T](ICustomAttributeProvider attributeProvider)
   at Microsoft.Internal.AttributeServices.GetFirstAttribute[T](ICustomAttributeProvider attributeProvider)
   at System.ComponentModel.Composition.Hosting.AssemblyCatalog.get_InnerCatalog()
   at System.ComponentModel.Composition.Hosting.AssemblyCatalog.GetEnumerator()
   at System.Linq.EnumerableQuery`1.GetEnumerator()
   at System.Linq.EnumerableQuery`1.System.Collections.Generic.IEnumerable.GetEnumerator()
   at System.Collections.Generic.List`1..ctor(IEnumerable`1 collection)
   at System.Linq.Enumerable.ToList[TSource](IEnumerable`1 source)
   at DotNetNuke.ExtensionPoints.SafeDirectoryCatalog..ctor(String directory)
   at DotNetNuke.ExtensionPoints.ExtensionPointManager.InitializeMefCompositionContainer()
   at DotNetNuke.ExtensionPoints.ExtensionPointManager..cctor()
   at DotNetNuke.ExtensionPoints.ExtensionPointManager.ComposeParts(Object[] attributeParts)
   at DotNetNuke.Common.Internal.EventHandlersContainer`1..ctor()
toggleusermode
when using personabar PAGES/
and selecting a page menu dropdown EDIT
Page loads with error. https://website.org/Defau...nvocation.&content=0
Reloading the page maintains the error
Admin Log shows:
AbsoluteURL:/Default.aspx
ExceptionGUID:f7f7ddd2-3593-4a06-9c47-25118fa79609
AssemblyVersion:9.8.0
PortalId:0
UserId:1
TabId:114
RawUrl:/Default.aspx?tabid=114&error=Exception+has+been+thrown+by+the+target+of+an+invocation.&content=0
Referrer:https://nvl.org/om-nvl/in-english
UserAgent:Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.67 Safari/537.36
ExceptionHash:I/Mp/KHISCzxAaXgCig6AtA/JF4=
Message:Exception has been thrown by the target of an invocation.
StackTrace:
InnerMessage:Exception has been thrown by the target of an invocation.
InnerStackTrace:
   at System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandleInternal& ctor, Boolean& bNeedSecurityCheck)
   at System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark)
   at System.RuntimeType.CreateInstanceDefaultCtor(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark)
   at System.Activator.CreateInstance[T]()
   at DotNetNuke.Framework.ServiceLocator`2.InitInstance() in D:\a\1\s\DNN Platform\Library\Framework\ServiceLocator.cs:line 47
   at System.Lazy`1.CreateValue()
   at System.Lazy`1.get_Value()
   at DotNetNuke.Framework.ServiceLocator`2.get_Instance() in D:\a\1\s\DNN Platform\Library\Framework\ServiceLocator.cs:line 74
   at Dnn.EditBar.UI.Items.AddModuleMenu.Visible() in D:\a\1\s\Dnn.AdminExperience\EditBar\Dnn.EditBar.UI\Items\AddModuleMenu.cs:line 56
   at Dnn.EditBar.UI.Controllers.EditBarController.<>c.b__3_0(BaseMenuItem m) in D:\a\1\s\Dnn.AdminExperience\EditBar\Dnn.EditBar.UI\Controllers\EditBarController.cs:line 72
   at System.Linq.Enumerable.WhereListIterator`1.MoveNext()
   at System.Linq.Buffer`1..ctor(IEnumerable`1 source)
   at System.Linq.OrderedEnumerable`1.d__1.MoveNext()
   at Dnn.EditBar.UI.Controllers.EditBarController.GetMenuItems() in D:\a\1\s\Dnn.AdminExperience\EditBar\Dnn.EditBar.UI\Controllers\EditBarController.cs:line 71
   at Dnn.EditBar.UI.Controllers.ContentEditorManager.OnInit(EventArgs e) in D:\a\1\s\Dnn.AdminExperience\EditBar\Dnn.EditBar.UI\Controllers\ContentEditorManager.cs:line 113
   at System.Web.UI.Control.AddedControl(Control control, Int32 index)
   at System.Web.UI.ControlCollection.Add(Control child)
   at Dnn.EditBar.UI.HttpModules.EditBarModule.OnSkinInit(Object sender, SkinEventArgs e) in D:\a\1\s\Dnn.AdminExperience\EditBar\Dnn.EditBar.UI\HttpModules\EditBarModule.cs:line 80
   at DotNetNuke.UI.Skins.Skin.InvokeSkinEvents(SkinEventType skinEventType) in D:\a\1\s\DNN Platform\Library\UI\Skins\Skin.cs:line 799
   at DotNetNuke.UI.Skins.Skin.OnInit(EventArgs e) in D:\a\1\s\DNN Platform\Library\UI\Skins\Skin.cs:line 541
   at Mandeeps.DNN.Skins.Porto.Home.OnInit(EventArgs e)
   at DotNetNuke.Framework.DefaultPage.OnInit(EventArgs e) in D:\a\1\s\DNN Platform\Website\Default.aspx.cs:line 296
   at System.Web.UI.Control.d__225.MoveNext()
Source:
FileName:
FileLineNumber:0
FileColumnNumber:0
Method:
Server Name: RD0015xxx53
Is this a new install? An upgrade?
its an upgrade from 9.3.2
as said works fine locally but unfortunatly not on  production Azure server
That's probably a clue ...
I installed website with most of install / release files and then upgraded over that. and got it working.
thanks for suggestion Joe Craig
I'm glad yo got it working!
The installation works locally, but not on the production Azure server since it's an upgrade from 9.3.2. My method was to install most of the installation and release files, then upgrade them later. I got it to work from https://calculerunpourcentage.net/.
