Using SendGrid with API Keys
SendGrid now requires you to use an API key rather than a username and password to send emails.
See: https://sendgrid.com/docs...-method-to-api-keys/
Is it possible to configure DNN to use a SendGrid API key?
Thank You
Ok I just found this, this should work:
https://sendgrid.com/docs...g-with-the-smtp-api/
It describes how to use SMTP where the username is "apikey"
This page seems to indicate that this is ok:
https://sendgrid.com/docs...sername-and-password
You can use this plugin which I found on the DNN store https://store.dnnsoftware...cation-authorization. I used this plugin on an internal form submission. This plugin has support for third party tokens and can call third party apis.
