ToggleUserMode error
I've got a (big) problem with Edit Pencil to add module at one page: using F12 function, I see that ToggleUserMode return 500 error code. This is the error
{Message: "An error has occurred.",…}
ExceptionMessage: "An error occurred when trying to create a controller of type 'ControlBarController'. Make sure that the controller has a parameterless public constructor."
ExceptionType: "System.InvalidOperationException"
InnerException: {Message: "An error has occurred.",…}
ExceptionMessage: "Eccezione generata dalla destinazione di una chiamata."
ExceptionType: "System.Reflection.TargetInvocationException"
ExceptionMessage: "L'inizializzatore di tipo di 'DotNetNuke.ExtensionPoints.ExtensionPointManager' ha generato un'eccezione."
ExceptionType: "System.TypeInitializationException"
ExceptionMessage: "Non è stato possibile caricare il file o l'assembly 'System.Runtime, Version=4.2.1.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' o una delle relative dipendenze. Impossibile trovare il file specificato."
ExceptionType: "System.IO.FileNotFoundException"
StackTrace: "   in System.ModuleHandle.ResolveType(RuntimeModule module, Int32 typeToken, IntPtr* typeInstArgs, Int32 typeInstCount, IntPtr* methodInstArgs, Int32 methodInstCount, ObjectHandleOnStack type)\r\n   in System.ModuleHandle.ResolveTypeHandleInternal(RuntimeModule module, Int32 typeToken, RuntimeTypeHandle[] typeInstantiationContext, RuntimeTypeHandle[] methodInstantiationContext)\r\n   in System.Reflection.RuntimeModule.ResolveType(Int32 metadataToken, Type[] genericTypeArguments, Type[] genericMethodArguments)\r\n   in System.Reflection.CustomAttribute.FilterCustomAttributeRecord(CustomAttributeRecord caRecord, MetadataImport scope, Assembly& lastAptcaOkAssembly, RuntimeModule decoratedModule, MetadataToken decoratedToken, RuntimeType attributeFilterType, Boolean mustBeInheritable, Object[] attributes, IList derivedAttributes, RuntimeType& attributeType, IRuntimeMethodInfo& ctor, Boolean& ctorHasParameters, Boolean& isVarArg)\r\n   in System.Reflection.CustomAttribute.GetCustomAttributes(RuntimeModule decoratedModule, Int32 decoratedMetadataToken, Int32 pcaCount, RuntimeType attributeFilterType, Boolean mustBeInheritable, IList derivedAttributes, Boolean isDecoratedTargetSecurityTransparent)\r\n   in System.Reflection.CustomAttribute.GetCustomAttributes(RuntimeAssembly assembly, RuntimeType caType)\r\n   in System.Reflection.RuntimeAssembly.GetCustomAttributes(Type attributeType, Boolean inherit)\r\n   in Microsoft.Internal.AttributeServices.GetAttributes[T](ICustomAttributeProvider attributeProvider)\r\n   in Microsoft.Internal.AttributeServices.GetFirstAttribute[T](ICustomAttributeProvider attributeProvider)\r\n   in System.ComponentModel.Composition.Hosting.AssemblyCatalog.get_InnerCatalog()\r\n   in System.ComponentModel.Composition.Hosting.AssemblyCatalog.GetEnumerator()\r\n   in System.Linq.EnumerableQuery`1.GetEnumerator()\r\n   in System.Linq.EnumerableQuery`1.System.Collections.Generic.IEnumerable.GetEnumerator()\r\n   in System.Collections.Generic.List`1..ctor(IEnumerable`1 collection)\r\n   in System.Linq.Enumerable.ToList[TSource](IEnumerable`1 source)\r\n   in DotNetNuke.ExtensionPoints.SafeDirectoryCatalog..ctor(String directory)\r\n   in DotNetNuke.ExtensionPoints.ExtensionPointManager.InitializeMefCompositionContainer()\r\n   in DotNetNuke.ExtensionPoints.ExtensionPointManager..cctor()"
StackTrace: "   in DotNetNuke.ExtensionPoints.ExtensionPointManager.ComposeParts(Object[] attributeParts)\r\n   in DotNetNuke.ExtensionPoints.ExtensionPointManager..ctor()\r\n   in DotNetNuke.Web.Components.Controllers.ControlBarController..ctor()"
StackTrace: "   in System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandleInternal& ctor, Boolean& bNeedSecurityCheck)\r\n   in System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark)\r\n   in System.RuntimeType.CreateInstanceDefaultCtor(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark)\r\n   in System.Activator.CreateInstance[T]()\r\n   in DotNetNuke.Framework.ServiceLocator`2.InitInstance()\r\n   in System.Lazy`1.CreateValue()\r\n   in System.Lazy`1.LazyInitValue()\r\n   in System.Lazy`1.get_Value()\r\n   in DotNetNuke.Framework.ServiceLocator`2.get_Instance()\r\n   in DotNetNuke.Web.InternalServices.ControlBarController..ctor()\r\n--- Fine traccia dello stack da posizione precedente dove è stata generata l'eccezione ---\r\n   in Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteRuntimeResolver.VisitCreateInstance(CreateInstanceCallSite createInstanceCallSite, ServiceProviderEngineScope scope)\r\n   in Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteVisitor`2.VisitCallSite(IServiceCallSite callSite, TArgument argument)\r\n   in Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteRuntimeResolver.VisitScoped(ScopedCallSite scopedCallSite, ServiceProviderEngineScope scope)\r\n   in Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteVisitor`2.VisitCallSite(IServiceCallSite callSite, TArgument argument)\r\n   in Microsoft.Extensions.DependencyInjection.ServiceLookup.DynamicServiceProviderEngine.<>c__DisplayClass1_0.b__0(ServiceProviderEngineScope scope)\r\n   in Microsoft.Extensions.DependencyInjection.ServiceLookup.ServiceProviderEngine.GetService(Type serviceType, ServiceProviderEngineScope serviceProviderEngineScope)\r\n   in Microsoft.Extensions.DependencyInjection.ServiceLookup.ServiceProviderEngineScope.GetService(Type serviceType)\r\n   in DotNetNuke.Web.Api.Internal.DnnDependencyResolver.GetService(Type serviceType)\r\n   in System.Web.Http.Dispatcher.DefaultHttpControllerActivator.GetInstanceOrActivator(HttpRequestMessage request, Type controllerType, Func`1& activator)\r\n   in System.Web.Http.Dispatcher.DefaultHttpControllerActivator.Create(HttpRequestMessage request, HttpControllerDescriptor controllerDescriptor, Type controllerType)"
StackTrace: "   in System.Web.Http.Dispatcher.DefaultHttpControllerActivator.Create(HttpRequestMessage request, HttpControllerDescriptor controllerDescriptor, Type controllerType)\r\n   in System.Web.Http.Tracing.Tracers.HttpControllerActivatorTracer.<>c__DisplayClass2.b__0()\r\n   in System.Web.Http.Tracing.ITraceWriterExtensions.TraceBeginEnd(ITraceWriter traceWriter, HttpRequestMessage request, String category, TraceLevel level, String operatorName, String operationName, Action`1 beginTrace, Action execute, Action`1 endTrace, Action`1 errorTrace)\r\n   in System.Web.Http.Tracing.Tracers.HttpControllerActivatorTracer.System.Web.Http.Dispatcher.IHttpControllerActivator.Create(HttpRequestMessage request, HttpControllerDescriptor controllerDescriptor, Type controllerType)\r\n   in System.Web.Http.Controllers.HttpControllerDescriptor.CreateController(HttpRequestMessage request)\r\n   in System.Web.Http.Tracing.Tracers.HttpControllerDescriptorTracer.<>c__DisplayClass2.b__0()\r\n   in System.Web.Http.Tracing.ITraceWriterExtensions.TraceBeginEnd(ITraceWriter traceWriter, HttpRequestMessage request, String category, TraceLevel level, String operatorName, String operationName, Action`1 beginTrace, Action execute, Action`1 endTrace, Action`1 errorTrace)\r\n   in System.Web.Http.Tracing.Tracers.HttpControllerDescriptorTracer.CreateController(HttpRequestMessage request)\r\n   in System.Web.Http.Dispatcher.HttpControllerDispatcher.d__1.MoveNext()"
Now, I use DNN 9.9.0 (start from 9.1.1): I do update to try to resolve the problem but no success
What can I check to solve the problem?
Which version of DNN?
Posted By Joe Craig on 07 May 2021 09:37 AM
Hi Joe,
actually I've got DNN 9.9.0
Introduction: in my VS solution (fully of .NET 4.8 project), I added a .NET Core 3.1 project to implement some web service
At compile time, \bin contains a netcoreapp3.1: I remove the folder and the problem solved
Why it happens? I would like understand the situation to avoid this error in future
