Trying to configure DNN_ActiveDirectoryAuthentication
Trying to use V7 with 9.1.1, I set it up based on a number of posts I have seen and yet everytime i try and login after setting it up I can't.
No error, just a jump back to the login page, is there a clear document that gives me how to set this up, and not miss something, because i must be somewhere.
Hi Jeff,
I know there are several options out there. Are you using https://github.com/DNNCom.../DNN.ActiveDirectory ?
So, the documentation you are referring to would be https://github.com/DNNCom...ActiveDirectory/wiki ?
If your desired answer is not coming up here, my recommendaction would be to start there.
If you are in a bit more of a hurry, there is always https://www.glantonmodules.com/
In my case I would purchase the module including installation support. They have always been able to get things working. And there is a refund if they can not get the job done. yes, it costs money but it saves a ton of time.
Thanks for this, have replied on another thread, basically saying am going to use AD pro.
