Unable to change "Output Cache Provider" in Module Settings
Hi -
Due to some errors I'm seeing (General Exception: The required anti-forgery cookie "__RequestVerificationToken" is not present. " ). I was advised to set the Page Settings >> Output Cache Provider setting to None (under Page Settings > Advanced > More ). (My pages were already set this way.
I was also advised to do the same inside Module Settings for my Action Forms (Module Settings > Page Settings > Cache Settings > Output Cache Provider)
However, when I change that setting from "File" to "None Specified" and hit "Update", and refresh the page,  the setting goes back to "File". It doesn't allow me to change the setting to "None Specified". Any idea why this is happening, or how I can actually change that setting?
Tom
If your question is related to Action Forms, I think that DNNSharp is best equipped to answer that question.
In the meantime, which version of DNN and ActionForms are you using?
Thanks - Yes I am asking on the DNN Sharp forums as well.
I did notice that I cant get the Output Cache Privider setting to change (in Module settings) , even for a simple HTML module (so the issue is not only in Action Forms)
I'm running DNN 9.6.1 - Action Form 5.1.54
Thanks for responding!
I'm able to change for HTML modules (that's all I tried) in a 9.7.0 installation.
Are you getting any errors? Check the log4net logs, too.
Thanks Joe - the original issue that caused me to look into this is that I am seeing errors in Action Forms that say:
"The required anti-forgery cookie "__RequestVerificationToken" is not present."
To fix this I was told to set the Output Cache Provider to None (for both Page settings, and Module Settings) .
But I can't get this setting to work in Module settings
I looked in the error logs and don't see anything related to Output Cache Provider
Tom
Any idea why I can't set the Output Cache provider to None in Module Settings? When I set to None Specified, it reverts back to "File". It also has an "Inherited" label next to it, but the Page setting for Output Cache Provider is already "None".
There's even a note saying that the module (Action Form) recommends the setting to be "None", but DNN won't allow me to set it that way. And I dont see anything in the logs related to Output Cache Provider
Tom
Did DNNSharp respond to your question?
I know a lot of time has passed, but I'm still seeing this issue. I have since upgraded DNN to 9.9.1
In the thread on DNN Sharp (now called PlantAnApp) forum. I was advised to update the Output Cache Provider to None
As I wrote in the thread :
The Page Settings > Advanced > More > Output Cache Provider setting is already set to "None" on the form pages.
In Settings > Servers > Module Cache Provider, there is no option to set to "none" (same for Page Output Cache Provider)
In the Module itself, Settings >Page Settings > Output Cache Provider, there *is* an option to set it to "None", but when I do, and try to Save, the setting reverts back to "File"
I'm wondering whether there is something else I can do to change this setting?
(Here's the thread itself https://community.plantan...on-Details?qid=1169)
-Tom
I was advised by someone at DNNSharp to turn on the 'SSL Enabled' setting at Settings > Security > More.
So I've done that and will keep an eye out to see if it fixes these errors from occurring.
I'm still seeing the error (General Exception: The required anti-forgery cookie "__RequestVerificationToken" is not present. " ). Even with the 'SSL Enabled' setting (at Settings > Security > More) turned on.
Does anyone know if there are any other ways I can try to fix this error from occurring?
Tom
