WORD Tpye text editor missing.
Page 3 of 4 << < 1234 > >>
OK, found something different! Went to one of the site I just installed and have not started working on it yet. The editor works on www.brilliantbeading.com but not on www.usmvmcc4.org. So it must be somethings in my skin/theme I am using very old data for that back oh like 7 years old. The bad code has got to be in here. www.dalegraham.com/problemskin.zip  Use Gold-Layout1 and
Gold-Layout1-1
Posted By DaleGraham on 13 Dec 2019 12:15 PM
Gold-Layout1-1
Right, that's what I responded to.
I checked both sites and saw that the second one has the wrong doctype, which can be corrected with the file I sent you, but I think I had the casing wrong (Skin vs skin)
in the .ascx files, you can get rid of the stuff related to Control Panel, but that's not what's causing the problem.
On my local machine, the editor works when I add the skin.doctype.xml file
ok I uploaded Gold-Layout1-1.doctype.xml into the portal/_default/skins/en1 renamed Gold-layout1-1.doctype.xml
Now then... If I use the Gold-Layout-1.ascx I can use the features in the editor! Yeah! but renaming gold-layout-1-1 caused it no to be an option in selection of the page format. So I changed a couple of pages to gold-layout-1 and can in fact use the editor. Sorry if I am going a little slow over here. Real newbieish…
I think it was the upper case S that was causing it not to work.
skin.doctype.xml should work for all ascx files, but you can also create one for each ascx file..
Posted By DaleGraham on 13 Dec 2019 12:42 PM
yes, I forgot it's case sensitive, sorry about that.
well it works on the live server but not my local machine. Will restart app and see what happens
Timo, I don't get it. I did the same skin.doctype.xml in the actual skin/en1 folder just like the server and my local machine does not have access to the editor features.
