WORD Tpye text editor missing.
Page 2 of 4 << < 1234 > >>
Dale,
If you aren't seeing DNN Connect CKEditor Provider on the list when you use the dropdown to view Providers, something definitely is wrong.
What do you mean "it is in setup"? Is it in the Available Extensions tab on the Extensions page?
One more thing. Go to Settings, Site Settings. Click on the Site Behavior tab, and then the More sub tab. That will open the HTML Editor Manager section and there is a button that says "Open HTML Editor Manager." Click it. Does it show that the Current Provider isDNNConnect.CKE?
Yes sir I have checked several places and see DNNConnect.CKE as the default HTML editor. Here is a screen shot.
http://www.dalegraham.com/ckeditor.png
Well, darn it! I'm officially out of ideas.
No Chuckie Cheese for you Joe. LoL. I even tried it from 3 different machines. I got no idea.
Thanks Joe. Dale Graham
OK, I don't need Chuckie Cheese anyway ...
How are you installing DNN? Try doing an install using nvQuickSite. Does it work then.
Are all of your installs on all 3 machines using a similar install of IIS? Perhaps there's something missing in your IIS configuration? No idea what that might be, though ...
OK, found something different! Went to one of the site I just installed and have not started working on it yet. The editor works on www.brilliantbeading.com but not on www.usmvmcc4.org. So it must be somethings in my skin/theme I am using very old data for that back oh like 7 years old. The bad code has got to be in here. www.dalegraham.com/problemskin.zip  Use Gold-Layout1 and
Gold-Layout1-1
www.usmvmcc4.org  is an html site and not xhtml or html5, that could cause this.
Drop this file in the skin folder and see if that helps. http://test.timo-design.nl/dnn/Skin.doctype.xml
Timo, no change. Did you see the note I left for Joe?
The site is still not HTML 5.
The file I posted needs to be in the folder where the ascx files are.
Please rename it to :  skin.doctype.xml (lowercase)
If that does not work, rename the xml file to Gold-Layout1-1.doctype.xml please.
Posted By DaleGraham on 13 Dec 2019 12:08 PM
not sure which one you mean..
