WORD Tpye text editor missing.
Page 1 of 41234 > >>
DNN9.4.4  it also did it in 9.2.x   When I go to edit my work and the editor comes up and I see all the buttons, but nothing funcntions.   When I type all I get is plain text.  Please advise and Thank you been away from DNN about 4 years now.  Dale Graham
I just tested the default editor in DNN 9.4.4 RC001 and it worked for me. What do you mean with 'nothing works'. If you highlight some text and press the Bold button it should become Bold. If that does not work can you the console in your browser and check for errors?
This happens very often when you choose "Basic Textbox" instead of "Rich Text Editor" in the little dropdown on the right below the editing zone.
I have richtext selected.
I can highlight text and press centering , bold, italics, font size, nothing changes.  the was a fresh 9.2.x install and upgraded to 9.4.1, then upgraded tp 9.4.4
Is the DNN Connect CKEditor Provider installed as a Provider on the Extensions page?
Joe, no it is not on the extensions page but it is in setup. And I see it in the file list of 9.4.4
OK the urgency of this issue just went up.   $50 Chuckie Cheese gift card to whoever helps me fix this issue.  I have a site I made live, but it's all small text and no graphics. And DNN Connect CKEditor is in the web.config file. Please advise.
Thanks  Dale Graham
When you press F12 and check the "Console" are there any JS errors?
Timo I do not know what to look for I am very new to this.  Contact me and I have a test user set up with admin privledges.
Thanks Dale Graham (fng)
