Accordion effect to show and hide texts
Is it possible to add accordion texts in the text editor below?
My idea is to insert several titles and in these titles I insert the contents relating to the titles.
for example:
It appears that you're asking a question about a third-party module called 2sxc.  You should ask your questions about that module in their community support area.  😉
Stack Overflow using the tag of "2sxc" is also a great way to get community support. That said, I have no problem trying to help here. :)
What you are showing seems to be an editing experience for a rich text field within a particular content type. In general, the editing experience is built-in. However, you can use an Empty field to contain fields within an accordion section (which you can default to expanded or collapsed via field settings).
I sometimes do that in a simple HTML module, so it should not be too difficult to realize it in any of the all purpose modules like 2sxc or Open Content - as it is already in DNN :-)
The documentation is a bit old, but still valid: DNN UX Guide > UI Patterns > Panels (dnnsoftware.com)
