How to run DataProvider.Instance().ExecuteReader without ObjectQualifier
I've an old DNN that use ObjectQualifier and been upgrade to latest DNN, the previous developer create some complex StoreProcedured that doesn't use ObjectQualifier.
Because of performance issue, to speed up I try to run it with DataReader:
`var completeCourses = CBO.FillCollection(DataProvider.Instance().ExecuteReader(SP_CompletedCourse, userIds, timePeriodId);`
The problem with code above, it looking for StoreProcedure with ObjectQualifier `{objectQualifier}SP_CompletedCourse` that not exist.
Is it possible to ExecuteReader without {objectQualifier} ?
If it not possible, I probably will end up duplicate the SP
I have only ever worked on 1 website with a objectqualifier, usually it's just empty. I am unsure if you can just ignore an object qualifier is it exists on the database.
However, I doubt changing the SPROC to use the dataprovider will give you any performance benefit. Usually the speed problem is in the SPROC or table index, If I have to look for performance my first step is always to look at the indexes on the table and is the SPROC using them correctly. After that start looking at the structure of the SPROC, it's amazing how much time you can find with SQL Server.
Assuming it is DNN DataProvider is aware of the object qualifier and all sql objects should have it.
The correct answer would be the extension needs to be updated to handle that scenario including it's install/upgrade scripts. You could copy the procedure but any updates to the said module won't be aware that you are using a copy.
The original developer create a custom module that not have source code. So update the original module is not possible.
Tables and store procedure don't have Object Qualifier while the Site it self was using Object Qualifier.
Because there's so many data and a complex SP, DAL 2 was taking a bit of time, wonder if it because of reflection.
Use DataReader and simple populate IList of object speed up a bit.
I ended up duplicate and simplify the SP, as the old SP might still use somewhere else.
I have seen cases where the developer has done a lot of manipulation with Linq after the data is returned, which is not a bad idea, but large amounts of data can give some issues in performance. If that is the case, without the source code your going to find it difficult to get more improvement.
