DNN Module deployment by PolyDeploy Extension
I have installed PolyDeploy Extension on my DNN website to install/update modules on my website via PolyDeploy scripts. BUT PolyDeploy is giving 403 response while doing module deployment onto my DNN website.
I have correctly installed the extension as it appears fine under Extensions section when I log in into my DNN site with admin credentials. Also, When I edit the PolyDeploy page from my DNN website admin login, it does not show any API Users or whitelisted IPs, BUT I had created API Users in past.
Any idea on solving this please? Any help would be very much appriciated..!
Details Error is:
System.Net.Http.HttpRequestException | Response status code does not indicate success: 403 (Forbidden).
   at DeployClient.API.d__2.MoveNext() in C:\DNNDev\CantarusCore\PolyDeploy\DeployClient\API.cs:line 37
   at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task)
   at DeployClient.Program.
d__2.MoveNext() in C:\DNNDev\CantarusCore\PolyDeploy\DeployClient\Program.cs:line 97
Just to be sure: PolyDeploy requires a Host (SuperUser) account, not an Admin - as installation and upgrading of DNN and extensions require this. If that is ensured, please log the error to Issues · DNNCommunity/PolyDeploy (github.com).
Most likely, you are attempting to use/access PolyDeploy using an IP address that's not yet in the allow list. When this is the case on a remote VM/server, I generally will create the record using a local dev version of the site, then add it to production using SQL.
