9.1.1 to 9.4 upgrade SQL errors
I'm attempting to upgrade DNN 9.1.1 to 9.4 and keep getting the following error right away.  How do I get around this issue?
0:23 Minutes   |   0% ERROR occured - System.Data.SqlClient.SqlException (0x80131904): The object 'vw_PortalBase' is dependent on column 'ProcessorPassword'. ALTER TABLE ALTER COLUMN ProcessorPassword failed because one or more objects access this column. at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction) at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose) at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady) at System.Data.SqlClient.SqlCommand.RunExecuteNonQueryTds(String methodName, Boolean async, Int32 timeout, Boolean asyncWrite) at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(TaskCompletionSource`1 completion, String methodName, Boolean sendToPipe, Int32 timeout, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry) at System.Data.SqlClient.SqlCommand.ExecuteNonQuery() at DotNetNuke.Data.SqlDatabaseConnectionProvider.ExecuteNonQuery(String connectionString, CommandType commandType, Int32 commandTimeout, String query) at DotNetNuke.Data.SqlDataProvider.ExecuteScriptInternal(String connectionString, String script, Int32 timeoutSec) ClientConnectionId:9f111376-db51-4693-9157-8fa029175ba7 Error Number:5074,State:1,Class:16 /*************************************************************************/ /***** DNN-4350: add encryption capability for PortalSettings values *****/ /*************************************************************************/ IF EXISTS( SELECT 1 FROM INFORMATION_SCHEMA.COLUMNS WHERE TABLE_NAME = N'Portals' AND COLUMN_NAME = N'ProcessorPassword' ) BEGIN ALTER TABLE dbo.[Portals] ALTER COLUMN ProcessorPassword nvarchar(100) END
Updating Database
Updating Extensions
most likely, you installed my TurboScripts before (you may verify by checking HostSettings table for existence of any Turbo... settingname). In this case, you need to perform an extra step prior to uprade: you need to run TurboUnSchema script before triggering the upgrade. Afterwards you should run TurboDNN and TurboSchema again. I am currently working on he version for DNN 9.4.1 whch should be available within the next couple of days.
