9.4 post upgrade issues - critical error editing Module Settings
After upgrading from DNN 9.32 to 9.4, I am not able to edit any module settings.  It throws the exception below:
AbsoluteURL:/Default.aspx
ExceptionGUID:0cfdb909-afd2-4b05-8648-867ec967cab8
AssemblyVersion:9.4.0
PortalId:4
UserId:2
TabId:70
RawUrl:/Home/ctl/Module/ModuleId/520?ReturnURL=/&popUp=true
UserAgent:Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 Edge/18.17763
ExceptionHash:CCrmVuhPDrbed/aLPNeJ1ApISic=
Message:Sequence contains more than one matching element
StackTrace:
InnerMessage:Sequence contains more than one matching element
InnerStackTrace:
at System.Linq.Enumerable.SingleOrDefault[TSource](IEnumerable`1 source, Func`2 predicate) at DotNetNuke.Framework.JavaScriptLibraries.JavaScriptLibraryController.GetLibrary(Func`2 predicate) at DotNetNuke.Web.UI.WebControls.Internal.DnnComboBox.RegisterRequestResources() at DotNetNuke.Web.UI.WebControls.Internal.DnnComboBox.OnPreRender(EventArgs e) at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Control.PreRenderRecursiveInternal() at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
Source:
FileName:
FileLineNumber:0
FileColumnNumber:0
Method:
I am getting the very same error too, whenever I try to look at any module settings.
Some others getting this error too.  Track at:
https://github.com/dnnsof...Platform/issues/2993
The fix identified by bdukes at this link: https://github.com/dnnsof...Platform/issues/2993 worked for me and TopCat to get the Module Settings working in 9.4 after upgrading from 9.32.  See the details by going to the post at that link.
Thank you!
