Upgrade to 9.4 Fails
Could not load file or assembly 'Microsoft.Extensions.DependencyInjection.Abstractions' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
<!--StartFragment-->Could not load file or assembly 'Microsoft.Extensions.DependencyInjection.Abstractions' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040) <!--EndFragment-->
I found this but it's not helpful in this situation.
https://stackoverflow.com...ncyinjection-abstrac
which DNN version were you upgrading from?
This is probably due to a required upgrade of 2Sxc before upgrading to DNN 9.4.0. DNN 9.4.0 includes a new dependency injection feature using version 2.1 of the .NET Core dependency injection framework, and a different version was already in use (probably by 2Sxc). If you can restart the upgrade and do the 2Sxc upgrade first, that should address the issue. Otherwise, you'll need to update the assembly bindings in the web.config with the correct version of that assembly.
I concur, having just discovered this solution myself. see:
https://dnncommunity.org/forums/aft/312
