Could not load file or assembly 'DotNetNuke.HttpModules' or one of its dependencies.
Hello, I'm new to DNN and upgrading our platform ultimately to 9.10. But I am recieving thebelow error when upgrading from 9.7.0 to 9.8.0 or 9.9.1. The binding in IIS seems to be poitning to the correct place, and I made previous upgrades from 9.2 to 9.7 without issue. It seems the upgrade from 9.7 to 9.8.0 or 9.9.1 (I've tried both) cause this error. Any thoughts on what it might be?
Server Error in '/DesktopModules/CompanyName/API-Storefront' Application.
Could not load file or assembly 'DotNetNuke.HttpModules' or one of its dependencies. The system cannot find the file specified.
Exception Details: System.IO.FileNotFoundException: Could not load file or assembly 'DotNetNuke.HttpModules' or one of its dependencies. The system cannot find the file specified.
Source Error:
<code>An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.</code>
Assembly Load Trace: The following information can be helpful to determine why the assembly 'DotNetNuke.HttpModules' could not be loaded.
<code>WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value &#91;HKLM\Software\Microsoft\Fusion!EnableLog&#93; (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value &#91;HKLM\Software\Microsoft\Fusion!EnableLog&#93;.
</code>
Stack Trace:
<code>&#91;FileNotFoundException: Could not load file or assembly 'DotNetNuke.HttpModules' or one of its dependencies. The system cannot find the file specified.&#93;
   System.RuntimeTypeHandle.GetTypeByName(String name, Boolean throwOnError, Boolean ignoreCase, Boolean reflectionOnly, StackCrawlMarkHandle stackMark, IntPtr pPrivHostBinder, Boolean loadTypeFromPartialName, ObjectHandleOnStack type) +0
   System.RuntimeTypeHandle.GetTypeByName(String name, Boolean throwOnError, Boolean ignoreCase, Boolean reflectionOnly, StackCrawlMark& stackMark, IntPtr pPrivHostBinder, Boolean loadTypeFromPartialName) +96
   System.Type.GetType(String typeName, Boolean throwOnError, Boolean ignoreCase) +65
   System.Web.Compilation.BuildManager.GetType(String typeName, Boolean throwOnError, Boolean ignoreCase) +59
   System.Web.Configuration.ConfigUtil.GetType(String typeName, String propertyName, ConfigurationElement configElement, XmlNode node, Boolean checkAptcaBit, Boolean ignoreCase) +49
&#91;ConfigurationErrorsException: Could not load file or assembly 'DotNetNuke.HttpModules' or one of its dependencies. The system cannot find the file specified.&#93;
   System.Web.Configuration.ConfigUtil.GetType(String typeName, String propertyName, ConfigurationElement configElement, XmlNode node, Boolean checkAptcaBit, Boolean ignoreCase) +515
   System.Web.Configuration.ConfigUtil.GetType(String typeName, String propertyName, ConfigurationElement configElement, Boolean checkAptcaBit) +29
   System.Web.Configuration.Common.ModulesEntry.SecureGetType(String typeName, String propertyName, ConfigurationElement configElement) +60
   System.Web.Configuration.Common.ModulesEntry..ctor(String name, String typeName, String propertyName, ConfigurationElement configElement) +68
   System.Web.HttpApplication.BuildIntegratedModuleCollection(List`1 moduleList) +221
   System.Web.HttpApplication.GetModuleCollection(IntPtr appContext) +1153
   System.Web.HttpApplication.RegisterEventSubscriptionsWithIIS(IntPtr appContext, HttpContext context, MethodInfo&#91;&#93; handlers) +139
   System.Web.HttpApplication.InitSpecial(HttpApplicationState state, MethodInfo&#91;&#93; handlers, IntPtr appContext, HttpContext context) +168
   System.Web.HttpApplicationFactory.GetSpecialApplicationInstance(IntPtr appContext, HttpContext context) +277
   System.Web.Hosting.PipelineRuntime.InitializeApplication(IntPtr appContext) +369
&#91;HttpException (0x80004005): Could not load file or assembly 'DotNetNuke.HttpModules' or one of its dependencies. The system cannot find the file specified.&#93;
   System.Web.HttpRuntime.FirstRequestInit(HttpContext context) +532
   System.Web.HttpRuntime.EnsureFirstRequestInit(HttpContext context) +111
   System.Web.HttpRuntime.ProcessRequestNotificationPrivate(IIS7WorkerRequest wr, HttpContext context) +724
</code>
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.8.4330.0
Did the upgrade complete successfully, and then this error appeared?
Yes, correct. The update does successfully complete
This looks like a problem with a 3rd party component (API-Storefront). Did you make sure, you are having a module version installed, which is compatible with latest version of DNN?
I had a similar problem with another assembly. Maybe this idea helps:
Upgrade DNN 9.9.1 to 9.10.x - DNN Open Source Community - Forums (dnncommunity.org)
Thanks for reply, API-Storefront is a virtual directory we are using to point to our storefront services folder. I do not beelive any 3rd pary modules are beign used here but I can confirm this and follow up
Thanks Michael, I did try using a system.web.http file version 5.2.7 in the bin directory, no luck either here.
I said "the idea". In your case it should be a file called "DotNetNuke.HttpModules.dll" with the same version number as your DNN installation (to get the version number of an assembly, right click the file, choose "Properties" and go to "Details").
