Developing Dnn.Users or other Modules
Is there a how-to guide for a developer to modify DNN Admin Modules (like Users, Roles, etc). For example if I wanted to add some additional controls to the Persona bar Users module. The same question goes for upgrading core messaging module. How would I start  extending it (to show messages specific to url for example)?.
Anything to get me in direction on how to quick start developing DNN Admin modules would be great. Do I download the source, build it and replace the files in my website project?
To know how to develop DNN modules, you can check from here:
https://www.dnnsoftware.c...evelopers/index.html
Best regards,
Linda
Website: https://www.dnngo.net
E-mail account: [email protected]
Skype: dnngo-linda
Posted By lukalev on 08 Jul 2019 04:06 PM
I wouldn't say there is a how-to guide for any specific module use case - only for technologies/patterns.
As for building a module for features that already exist in some form, your idea of beginning with existing source code is spot on.  This is discussed in DNNDocs a bit.  I wouldn't suggest doing this from within DNN's source code package/repo itself though.
Instead, I would suggest starting with an existing module template/pattern and then applying the existing source code to your new module, as required.
Basically for the persona bar modules, I can start by looking at some modules at https://github.com/dnnsof.../Dnn.AdminExperience
The manifest has a a registration for the persona bar module and the persona bar page where it lives. Then you basically load up html and optionally scripts and javascript. Some of those modules use React and the Dnn.React.Common bundle but a few of those are simpler and use just html and some knockout for bindings...
Note that if you do decide to use the Dnn.React.Common bundle, then you may have to update your module very often, so I would not recommend it at the moment. If what you want to add or improve is of general interest than I would also suggest creating an issue for it and if it is a common enough feature, it could be worth making that a pull request to include it in the platform.
Thanks for all the answers. I need to add that this video is also helpful (found by one of my colleagues): https://www.youtube.com/watch?v=oBhDqiQ9vOk
Yeah, one more view for my video :)
That being said, if the modifications you want to do on these admin modules you think are general enough to be of general use, you could also put an issue in github and then submit a pull request and get help if needed, etc. I am just saying this because if you replace the module but it has the same name, it will get overwritten on each update
