Upgrading from 7.2.1 to 9.2.2 DNNAjaxPanel error
Dear readers,
We are using dnn 7.2.1, when we want to upgrade tot 9.2.2 we upgrade in this order:
7.4.2
8.0.4
9.1.1
9.2.2
We do have to fix some of our extensions but that does not cause our issue. We go from a working 9.1.1 to a broken 9.2.2 with the following error:
DotNetNuke.Services.Exceptions.PageLoadException: Could not load type 'DotNetNuke.Web.UI.WebControls.DnnAjaxPanel' from assembly 'DotNetNuke.Web, Version=9.2.2.178, Culture=neutral, PublicKeyToken=null'. --->
System.TypeLoadException: Could not load type 'DotNetNuke.Web.UI.WebControls.DnnAjaxPanel' from assembly 'DotNetNuke.Web, Version=9.2.2.178, Culture=neutral, PublicKeyToken=null'.
at Evoq.Content.Library.ContentEditor.ContentEditorManager.CreateChildControls()
at System.Web.UI.Control.EnsureChildControls()
at System.Web.UI.Control.PreRenderRecursiveInternal()
That is all the information we get when it fails.So this is a really strange problem. Is there any module/extension that needs to be update so that it wont use the AjaxPanel anymore.
See:
https://www.dnnsoftware.c...telerik-removal.html
Kind regards,
Dirk Teulings
Could be the documents module?
https://www.dnnsoftware.c...nukemodulesdocuments
Otherwise, it would be convenient to have more info on what modules are being used.
These are the plugins that are used in the portal we get erros in:
Advanced URL Management    08.01.00
Console    08.00.04
Device Preview Management    08.00.04
Digital Asset Management    08.00.04
Dynamic Login    04.00.11
Dynamic Registration    04.10.70
Extensions    08.00.04
Google Analytics    08.00.04
Google Analytics Professional    08.01.00
HTML Pro    08.01.00
Journal    08.00.04
Languages    08.00.04
Lists    08.00.04
Log Viewer    08.00.04
Member Directory    08.00.04
Message Center    08.00.04
Pages    08.00.04
Portals    08.00.04
Recycle Bin    08.00.04
Search Admin    08.00.04
Search Results    08.00.04
Site Redirection Management    08.00.04
Site Wizard    08.00.04
Sitemap    08.00.04
Taxonomy Manager    08.00.04
Themes    08.00.04
User Switcher    08.01.00
Users And Roles    08.00.04
ViewProfile    08.00.04
Workflow Management    08.01.00
My first suspects are the "dynamic" modules. I think I have seen others post about upgrade issues.
Try upgrading those first. BTW, this looks like Evoq, right?
I will try upgrading those, and yes this is Evoq
Posted By Timo Breumelhof on 15 Jul 2019 08:30 AM
Indeed it was the Dynamic stuff, thanks for the help!
