DNN 10: Redirect loop, and error: Method not found: 'System.Collections.Generic.Dictionary'
Hi again -
Testing DNN 10.1.1 on a test website, in just one of my sites (portals), I'm getting a redirect loop "site redirected too many times", and in the logs I see this error:
Method not found: 'System.Collections.Generic.Dictionary`2 DotNetNuke.Entities.Portals.PortalController.GetPortalSettingsDictionary(Int32)'.
One thing about this particular site, is that when you browse to it, it takes you first to the login page, because all pages on this site are only accessible to logged in users. So that probably has somethng to do with the reirect issues. (Of course there is no such issue on the production site running DNN 9.13.3, or another test site running 9.13.7).
I've looked at the most common causes of redirect loops - SSL, URL Rewrite, incorrect portal alias, browser cache, etc, and none of those seem to be the issue.
I tried copying code from a different (working) skin on the page site skin, to see if the issue was in the skin/theme, but still get the redirect.
Anyone have any insight on how to fix this?
Thanks - more error detail below -
Tom
AbsoluteURL:/Default.aspx
ExceptionGUID:da30bf5b-334c-4143-a25b-98b2d7b5c654
AssemblyVersion:
PortalId:-1
UserId:-1
TabId:-1
RawUrl:
Referrer:
UserAgent:
ExceptionHash:sY+yfiiwdGQcrpdDDJ0jjDXbNcU=
Message:Method not found: 'System.Collections.Generic.Dictionary`2 DotNetNuke.Entities.Portals.PortalController.GetPortalSettingsDictionary(Int32)'.
StackTrace:
   at DotNetNuke.Authentication.OpenID.Config..ctor(Int32 portalID)
   at DotNetNuke.Authentication.OpenID.Config.GetConfig(Int32 portalId)
   at DotNetNuke.Authentication.OpenID.Login.get_Enabled()
   at DotNetNuke.Modules.Admin.Authentication.Login.BindLogin()
InnerMessage:
InnerStackTrace:
Source:DotNetNuke.Authentication.OpenID
FileName:
FileLineNumber:0
FileColumnNumber:0
Method:
Server Name: SCTAS35
I've had some issues with assigning login pages, but I've not found out exactly why.
My first suggestion would be to upgrade to v10.1.2 and see if the problem still exists.
It looks as though this redirect issue was fixed by removing two old Authentication extensions: DNN_OpenIDAuthentication and DNN_LiveIDAuthentication
I was also seeing an issue in Security >> Aunthentication >> Basic Login Settings as seen on this thread : https://dnncommunity.org/...in-dnn-10-1-1/#14165
I didn't suspect that these issues were related, but it appears to have fixed this issue!
