DnnJsInclude and Skinpath
Just upgraded from 10.1.1 to 10.2.0 then to 10.2.1 i had a number of js files included in the .ascx files via the following format:-
<dnn:DnnJsInclude runat="server" FilePath="../Common/js/jquery.sticky.js" PathNameAlias="SkinPath" />
These files are no longer loading, to work around this for now i've moved the files so they are off the root folder
<dnn:DnnJsInclude runat="server" FilePath="/Common/js/jquery.sticky.js" />
Ideally, i would prefer them to stay under the skin path, as we sometimes have a variation based on the skin
I guess that this https://github.com/dnnsof...n.Platform/pull/6919 might be the solution
Yes, I believe that fix is what you need, which will be included in the next release
If you want to verify the fix, testing https://github.com/dnnsof...ases/tag/v10.2.2-rc2 on a non-productino environment would be nice.
