ERROR DotNetNuke.UI.Skins.Skin.GetSkin(PageBase page) we trying to recompile
Once the website goes down, I delete everything in the temp folder referenced in the error and then website works again.    The website continues to stay up until  a restart  is triggered.   The website errors (see below)   until I delete the Temp folder again.
Exception Details: System.NullReferenceException: Object reference not set to an instance of an object.
Source Error:
<code>
&#91;No relevant source lines&#93;</code>
Source File: c:\inetpub\vhosts\baja-rentals.com\tmp\root\2fe956e6\1dc4f865\App_Web_j0vvlfrx.1.cs    Line: 0
Stack Trace:
<code>NullReferenceException: Object reference not set to an instance of an object.&#93;
   DotNetNuke.UI.Skins.Skin.GetSkin(PageBase page) +667
   DotNetNuke.Framework.DefaultPage.OnInit(EventArgs e) +87
   System.Web.UI.<InitRecursiveAsync>d__225.MoveNext() +571
   System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) +102
   System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) +64
   System.Web.Util.WithinCancellableCallbackTaskAwaiter.GetResult() +32
   System.Web.UI.<ProcessRequestMainAsync>d__523.MoveNext() +2619
&#91;PageLoadException: Object reference not set to an instance of an object.&#93;
   DotNetNuke.Services.Exceptions.Exceptions.ProcessPageLoadException(Exception exc, String URL) +451
   DotNetNuke.Framework.PageBase.OnError(EventArgs e) +743
   System.Web.UI.Page.HandleError(Exception e) +86
   System.Web.UI.<ProcessRequestMainAsync>d__523.MoveNext() +9165
   System.Web.UI.<ProcessRequestAsync>d__515.MoveNext() +525
   System.Web.UI.<ProcessRequestAsync>d__554.MoveNext() +507
   System.Web.TaskAsyncHelper.EndTask(IAsyncResult ar) +72
   System.Web.UI.Page.AsyncPageEndProcessRequest(IAsyncResult result) +76
   ASP.default_aspx.EndProcessRequest(IAsyncResult ar) in c:\inetpub\vhosts\baja-rentals.com\tmp\root\2fe956e6\1dc4f865\App_Web_j0vvlfrx.1.cs:0
   System.Web.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +9850009
   System.Web.HttpApplication.ExecuteStepImpl(IExecutionStep step) +50
   System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +163</code>
LOG FILE:
2021-12-09 00:13:35,912 [Generic281][Thread:24][ERROR] DotNetNuke.Services.Exceptions.Exceptions - DotNetNuke.Services.Exceptions.PageLoadException: Unhandled error loading page. ---> System.InvalidOperationException: No service for type 'DotNetNuke.UI.Modules.IModuleControlPipeline' has been registered.
   at Microsoft.Extensions.DependencyInjection.ServiceProviderServiceExtensions.GetRequiredService(IServiceProvider provider, Type serviceType)
   at Microsoft.Extensions.DependencyInjection.ServiceProviderServiceExtensions.GetRequiredService[T](IServiceProvider provider)
   at DotNetNuke.UI.Skins.Skin..ctor()
   at Vanjaro.Skin.Base..ctor()
   at ASP.portals__default_skins_vanjaro_base_ascx..ctor() in c:\inetpub\vhosts\baja-rentals.com\tmp\root\2fe956e6\1dc4f865\App_Web_pvty3thp.0.cs:line 0
   at __ASP.FastObjectFactory_app_web_pvty3thp.Create_ASP_portals__default_skins_vanjaro_base_ascx() in c:\inetpub\vhosts\baja-rentals.com\tmp\root\2fe956e6\1dc4f865\App_Web_pvty3thp.1.cs:line 0
   at System.Web.Compilation.BuildResultCompiledType.CreateInstance()
   at System.Web.UI.TemplateControl.LoadControl(IWebObjectFactory objectFactory, VirtualPath virtualPath, Type t, Object[] parameters)
   at System.Web.UI.TemplateControl.LoadControl(VirtualPath virtualPath)
   at DotNetNuke.UI.Skins.Skin.LoadSkin(PageBase page, String skinPath)
2021-12-09 00:13:35,918 [Generic281][Thread:24][ERROR] DotNetNuke.Services.Exceptions.Exceptions - DotNetNuke.Services.Exceptions.PageLoadException: Unhandled error loading page. ---> System.InvalidOperationException: No service for type 'DotNetNuke.UI.Modules.IModuleControlPipeline' has been registered.
   at ASP.portals__default_skins_xcillion_inner_ascx..ctor()
   at __ASP.FastObjectFactory_app_web_vo1yralo.Create_ASP_portals__default_skins_xcillion_inner_ascx()
2021-12-09 00:13:35,921 [Generic281][Thread:24][FATAL] DotNetNuke.Framework.PageBase - An error has occurred while loading page.
   at System.Web.UI.Control.d__225.MoveNext()
2021-12-09 00:13:35,922 [Generic281][Thread:24][ERROR] DotNetNuke.Services.Exceptions.Exceptions - ~/Default.aspx?tabid=3437&error=An unexpected error has occurred&content=0
2021-12-09 00:13:35,928 [Generic281][Thread:24][FATAL] DotNetNuke.Web.Common.Internal.DotNetNukeHttpApplication - DotNetNuke.Services.Exceptions.PageLoadException: Object reference not set to an instance of an object. ---> System.NullReferenceException: Object reference not set to an instance of an object.
   at DotNetNuke.Services.Exceptions.Exceptions.ProcessPageLoadException(Exception exc, String URL)
   at DotNetNuke.Framework.PageBase.OnError(EventArgs e)
   at System.Web.UI.Page.HandleError(Exception e)
   at System.Web.UI.Page.d__515.MoveNext()
   at System.Web.UI.Page.d__554.MoveNext()
   at System.Web.TaskAsyncHelper.EndTask(IAsyncResult ar)
   at System.Web.UI.Page.AsyncPageEndProcessRequest(IAsyncResult result)
   at ASP.default_aspx.EndProcessRequest(IAsyncResult ar) in c:\inetpub\vhosts\baja-rentals.com\tmp\root\2fe956e6\1dc4f865\App_Web_lvvkhbsk.2.cs:line 0
   at System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
2021-12-09 00:14:16,421 [Generic281][Thread:7][ERROR] DotNetNuke.Services.Exceptions.Exceptions - DotNetNuke.Services.Exceptions.PageLoadException: Unhandled error loading page. ---> System.InvalidOperationException: No service for type 'DotNetNuke.UI.Modules.IModuleControlPipeline' has been registered.
2021-12-09 00:14:16,430 [Generic281][Thread:7][ERROR] DotNetNuke.Services.Exceptions.Exceptions - DotNetNuke.Services.Exceptions.PageLoadException: Unhandled error loading page. ---> System.InvalidOperationException: No service for type 'DotNetNuke.UI.Modules.IModuleControlPipeline' has been registered.
2021-12-09 00:14:16,434 [Generic281][Thread:7][FATAL] DotNetNuke.Framework.PageBase - An error has occurred while loading page.
2021-12-09 00:14:16,435 [Generic281][Thread:7][ERROR] DotNetNuke.Services.Exceptions.Exceptions - ~/Default.aspx?tabid=3437&error=An unexpected error has occurred&content=0
2021-12-09 00:14:16,441 [Generic281][Thread:7][FATAL] DotNetNuke.Web.Common.Internal.DotNetNukeHttpApplication - DotNetNuke.Services.Exceptions.PageLoadException: Object reference not set to an instance of an object. ---> System.NullReferenceException: Object reference not set to an instance of an object.
2021-12-09 00:14:18,938 [Generic281][Thread:33][ERROR] DotNetNuke.Services.Exceptions.Exceptions - DotNetNuke.Services.Exceptions.PageLoadException: Unhandled error loading page. ---> System.InvalidOperationException: No service for type 'DotNetNuke.UI.Modules.IModuleControlPipeline' has been registered.
2021-12-09 00:14:18,945 [Generic281][Thread:33][ERROR] DotNetNuke.Services.Exceptions.Exceptions - DotNetNuke.Services.Exceptions.PageLoadException: Unhandled error loading page. ---> System.InvalidOperationException: No service for type 'DotNetNuke.UI.Modules.IModuleControlPipeline' has been registered.
2021-12-09 00:14:18,949 [Generic281][Thread:33][FATAL] DotNetNuke.Framework.PageBase - An error has occurred while loading page.
2021-12-09 00:14:18,950 [Generic281][Thread:33][ERROR] DotNetNuke.Services.Exceptions.Exceptions - ~/Default.aspx?tabid=3437&error=An unexpected error has occurred&content=0
2021-12-09 00:14:18,955 [Generic281][Thread:33][FATAL] DotNetNuke.Web.Common.Internal.DotNetNukeHttpApplication - DotNetNuke.Services.Exceptions.PageLoadException: Object reference not set to an instance of an object. ---> System.NullReferenceException: Object reference not set to an instance of an object.
I'm having a similar issue, what Temp folder are you refering in your post?
Posted By Jennfier on 09 Dec 2021 08:22 PM
Did you check the NTFS (application pool) settings on the folder?
Sometimes resetting them helps (force them from the root folder)
