Unable to Complete Recommended Telerik Removal Process after 9.10.2 Upgrade
We upgraded our DNN site to 9.10.2. The upgrade completed without a problem in both test and then production environments, and the Telerik removal process outlined here also went smoothly on test. But, when I attempted to repeat the same process in production, Step 10 broke our site, generating a server error complaining that the Telerik control were missing and rendering further action through the CMS impossible. Had to roll back to our backup and try again, but the same thing happened.
I figured out that I could manually copy the backed-up Telerik DLL files back in to "fix" the issue, but then of course we're back at Step 10 again and as soon as they're once again removed, site breaks. Also, I noticed something fishy when comparing test vs. production--the Digital Asset Management module is still listed under Installed Extensions on production, even though I deleted it including "all files" in step 8. It's listed as an installed module but the delete icon no longer appears next to it and the DigialAssets folder is no longer present under /DesktopModules. I wonder if this is culprit, but if it is I have no idea how to fix.
Any and all advice on this would be much appreciated!
When you say that you "deleted" the Digital Assets Module, did you do that via the DNN Extensions page?
Can you Edit the module on the Extensions page? If so, you should edit it to not be a premium module. After that, you may have a delete icon again.
If none of that works, can yo rollback again? If so, try deleting the Digital Assets Module before doing the upgrade.
It sounds like there are still telerik dependencies installed. As Joe said, you probably need to restore and start over. It's possible a step was missed or production might actually be different. Double-check things using the Telerik Identifier on the link you're following in DNN docs. :)
